{"issuer":"https://id.theiet.org","jwks_uri":"https://id.theiet.org/.well-known/openid-configuration/jwks","authorization_endpoint":"https://id.theiet.org/connect/authorize","token_endpoint":"https://id.theiet.org/connect/token","userinfo_endpoint":"https://id.theiet.org/connect/userinfo","end_session_endpoint":"https://id.theiet.org/connect/endsession","check_session_iframe":"https://id.theiet.org/connect/checksession","revocation_endpoint":"https://id.theiet.org/connect/revocation","backchannel_authentication_endpoint":"https://id.theiet.org/connect/ciba","pushed_authorization_request_endpoint":"https://id.theiet.org/connect/par","require_pushed_authorization_requests":false,"frontchannel_logout_supported":true,"frontchannel_logout_session_supported":true,"backchannel_logout_supported":true,"backchannel_logout_session_supported":true,"scopes_supported":["openid","profile","email","roles","identity_api","standards_viewer_api","messaging_api","eforms_api","enquiry_api","subscription_and_price","sd_cm_index_api","sd_cm_api","superoffice_integration_api","businesscenter_integration_api","terms_library_api","xxm_api","sarepta_api","epi_api","subscription_and_price.read","subscription_and_price.modify","subscription_management_api","authoring_tool_api","subscription_invoicing_api","sd_cm_sidecar","sd_subprice_sidecar","import_service_api","publisher_api","offline_access"],"claims_supported":["sub","name","family_name","given_name","middle_name","nickname","preferred_username","profile","picture","website","gender","birthdate","zoneinfo","locale","updated_at","email","email_verified","role"],"grant_types_supported":["authorization_code","client_credentials","refresh_token","implicit","password","urn:openid:params:grant-type:ciba"],"response_types_supported":["code","token","id_token","id_token token","code id_token","code token","code id_token token"],"response_modes_supported":["form_post","query","fragment"],"token_endpoint_auth_methods_supported":["client_secret_basic","client_secret_post"],"id_token_signing_alg_values_supported":["RS256"],"subject_types_supported":["public"],"code_challenge_methods_supported":["plain","S256"],"request_parameter_supported":true,"request_object_signing_alg_values_supported":["RS256","RS384","RS512","PS256","PS384","PS512","ES256","ES384","ES512","HS256","HS384","HS512"],"prompt_values_supported":["none","login","consent","select_account"],"authorization_response_iss_parameter_supported":true,"backchannel_token_delivery_modes_supported":["poll"],"backchannel_user_code_parameter_supported":true,"dpop_signing_alg_values_supported":["RS256","RS384","RS512","PS256","PS384","PS512","ES256","ES384","ES512"]}
